This article is reproduced from the 交叉编译OpenCV 4.5.4(包含交叉编译环境配置) - Duo - MilkV Community, and the original author is xiaomin
Optimizing OpenCV for C906 with Cross-Compilation
I. Getting the OpenCV Source Code
You can download the source code from the following link: 平头哥芯片开放社区-平头哥 (t-head.cn)
Choose the latest OpenCV-V1.0.3.r0-20230426.tar.gz file for download, and you’ll need to register an account.
It seems that the forum does not support uploading attachments, so everyone may need to download it themselves.
II. Obtaining the riscv-v Cross-Compilation Toolchain
These are precompiled tools from the Alcide platform, including an ELF compilation toolchain for C906L and two versions of the GNU and Musl toolchains.
I chose the toolchain with Musl.
You can download the cross-compilation toolchain from Alcide’s official repository on Ubuntu by running the following command:
wget https://sophon-file.sophon.cn/sophon-prod-s3/drive/23/03/07/16/host-tools.tar.gz
III. Installing the riscv-v Cross-Compilation Toolchain
After downloading, use the following command to extract the toolchain:
tar xvf host-tools.tar.gz
To make it more convenient for later use, create an environment setup script. Follow these steps:
Enter the cross-compilation toolchain directory:
cd host-tools
Create a script:
touch riscv-crosstool-env-init
Modify the script:
vi riscv-crosstool-env-init
Paste the following content into the script. Make sure to replace
HOST_TOOL_PATH
with your actual toolchain path, which you can obtain by runningpwd
in the shell while in that directory:HOST_TOOL_PATH=/home/xxx/milk-v/CV180x/host-tools export PATH="$HOST_TOOL_PATH/gcc/riscv64-linux-x86_64/bin:$HOST_TOOL_PATH/gcc/riscv64-linux-musl-x86_64/bin:$HOST_TOOL_PATH/gcc/riscv64-elf-x86_64/bin:$PATH" echo -e "\033[33;1mCross-Compilation Toolchain Environment Configuration Complete!\033[0m"
Save the file by pressing ESC, then typing
:q
Now, every time you want to use the cross-compilation toolchain, simply run:
source riscv-crosstool-env-init
Type riscv64
and then press TAB
to check if the current GCC toolchain is installed. The toolchains in the 1
section are for compiling firmware for real-time systems, while the ones in the 2
and 3
sections are for compiling Linux applications.
IV. Cross-Compiling OpenCV
Extract the OpenCV source code that you downloaded earlier:
tar xvf OpenCV-V1.0.3.r0-20230426.tar.gz
In the OpenCV/platforms/linux/ directory, make a copy of riscv64-gcc.toolchain.cmake and rename it to riscv64-musl-gcc.toolchain.cmake. Open the file and make the modifications as shown in the image provided in your article.
This version of CMake checks that the build is not in the source code directory, or else the cmake
command will fail. So, create a build directory at the same level as the source code:
mkdir OpenCV_build
Enter the build directory:
cd OpenCV_build
Execute the following compilation command (adjust paths as needed):
cmake /home/yxm/milk-v/CV180x/OpenCV -DCMAKE_TOOLCHAIN_FILE="/home/yxm/milk-v/CV180x/OpenCV/platforms/linux/riscv64-musl-gcc.toolchain.cmake" -DWITH_OPENCL=OFF -DBUILD_opencv_calib3d=ON -DBUILD_ZLIB=ON -DBUILD_PNG=ON -DBUILD_SHARED_LIBS=OFF -DCMAKE_BUILD_WITH_INSTALL_RPATH=1 -DCMAKE_INSTALL_PREFIX=./c906_install -DBUILD_CSI_CV=ON -DWITH_OPENMP=OFF -DWITH_PTHREADS_PF=OFF -DCORE=C906FDV -D BUILD_SHARED_LIBS=ON -D BUILD_opencv_features2d=ON -D BUILD_opencv_apps=OFF -D BUILD_TESTS=OFF -D BUILD_opencv_highgui=OFF -D BUILD_PERF_TESTS=OFF
/home/xxx/milk-v/CV180x/OpenCV
: Path to the extracted OpenCV source code files.-DCMAKE_TOOLCHAIN_FILE="/home/yxm/milk-v/CV180x/OpenCV/platforms/linux/riscv64-musl-gcc.toolchain.cmake"
: Replace this with your actual path.-DCMAKE_INSTALL_PREFIX=./c906_install
: Set the path wheremake install
will install the files.
After running the cmake
command successfully, it will generate the necessary configuration files for compilation.
Now, compile OpenCV with the following command (adjust the number after -j
based on your machine’s capabilities):
make -j4
This will take some time to complete, depending on your system.
V. Installation
After compilation, you can install OpenCV by running:
make install
You can find the installed files in the parent directory by running:
cd ..
In the build directory, you’ll see a c906_install/
directory containing the compiled OpenCV files.
VI. Testing
To test the OpenCV installation, create a test program to convert an image to grayscale. Create a main.cpp
file with the following content:
#include <ctime>
#include <iostream>
#include <opencv2/imgproc.hpp>
#include <opencv2/imgcodecs.hpp>
#include <opencv2/imgproc/types_c.h>
using namespace cv;
int main(int argc, char **argv) {
Mat image;
image = imread("./demo.jpg");
if (!image.data) {
printf("No image data (./demo.jpg)\n");
return -1;
} else {
printf("Read image successfully!\n");
Mat dst;
cvtColor(image, dst, CV_BGR2GRAY);
imwrite("image.jpg", dst);
printf("Conversion successful!\n");
Create a CMakeLists.txt
file to build the project using CMake:
cmake_minimum_required(VERSION 3.16.5)
project(opencv_test_demo)
set(CMAKE_CROSSCOMPILING TRUE)
set(CMAKE_SYSTEM_NAME Linux)
set(CMAKE_SYSTEM_PROCESSOR riscv64)
set(CMAKE_CXX_STANDARD 11)
# Uncomment and set TOOLCHAIN_DIR and the compiler paths if you didn't configure the environment.
# set(TOOLCHAIN_DIR "/home/yxm/milk-v/CV180x/host-tools/gcc/riscv64-linux-x86_64/bin")
# set(CMAKE_C_COMPILER "${TOOLCHAIN_DIR}/riscv64-unknown-linux-musl-gcc")
# set(CMAKE_CXX_COMPILER "${TOOLCHAIN_DIR}/riscv
64-unknown-linux-musl-g++")
# Set the compiler paths if you configured the environment.
set(CMAKE_C_COMPILER "riscv64-unknown-linux-musl-gcc")
set(CMAKE_CXX_COMPILER "riscv64-unknown-linux-musl-g++")
set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -march=rv64imafdcvxthead -mcmodel=medany -mabi=lp64d")
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -march=rv64imafdcvxthead -mcmodel=medany -mabi=lp64d")
# Set the path to the installed OpenCV library on your machine.
set(OPENCV_PATH /home/yxm/milk-v/CV180x/OpenCV_build/c906_install)
include_directories(${OPENCV_PATH}/include/opencv4)
link_directories(${OPENCV_PATH}/lib)
set(OPENCV_LIBS ${OPENCV_LIBS} opencv_core opencv_imgcodecs opencv_imgproc)
add_executable(${PROJECT_NAME} main.cpp)
target_link_libraries(${PROJECT_NAME} ${OPENCV_LIBS})
Compile your project using the cross-compilation toolchain:
mkdir build
cd build
cmake .. -DCMAKE_C_COMPILER=riscv64-unknown-linux-musl-gcc -DCMAKE_CXX_COMPILER=riscv64-unknown-linux-musl-g++
The target files compiled by opencv_test_demo.
Copy all the .so files generated in the previous compilation from the OpenCV c906_install/lib directory to the /usr/lib directory of the Duo file system. Then, import the opencv_test_demo program to the target board and run it to achieve grayscale conversion of the demo.jpg image.
V. Package Installation and Development Environment
We provide a package for easy setup, which can be used as mentioned above.
Since the forum does not support file uploads, the package has been uploaded to the official enterprise chat group.
VI. Troubleshooting
If you encounter issues when running the demo, please check the environment on your build system and the target board.
Ensure that the environment on your board matches your compilation environment. If there are any discrepancies, you may need to create a symbolic link to address the issue. For example, you can create a symlink for the missing library as follows:
ln -s /usr/lib64v0p7_xthead/lp64d/libc.so /lib/ld-musl-riscv64v_xthead.so.1
After addressing any environment mismatches and creating any necessary symbolic links, try running the demo again.
Run the demo once more.
