use gc2083 to test VI/VENC, but seems no data from mipi
hi, I use gc2083 to test the program(bind VI to Venc, and try to read 1 frame):
cv1800b test camera VI/VENC with gc2083 (github.com)
I have tested my camera by Milk-V Duo 摄像头VLC拉流 (2023-08-17 更新) - Duo - MilkV Community. I can get stream on PC.
while using my own program, the debug info:
[root@milkv-duo]~# ./mycamera
[camera_VI_init]-149: common pool[0] BlkSize 3110400
ISP Vipipe(0) Allocate pa(0x83640000) va(0x0x3fe7235000) size(291016)
stSnsrMode.u16Width 1920 stSnsrMode.u16Height 1080 25.000000 wdrMode 0 pstSnsObj 0x9dba8
[SAMPLE_COMM_VI_StartMIPI]-483: sensor 0 stDevAttr.devno 0
awbInit ver 6.8@2021500
0 R:1400 B:3100 CT:2850
1 R:1500 B:2500 CT:3900
2 R:2300 B:1600 CT:6500
Golden 1024 1024 1024
WB Quadratic:0
isWdr:0
ViPipe:0,===GC2083 1080P 30fps 10bit LINE Init OK!===
Module: [MIPI_RX], Build Time[#1 PREEMPT Mon May 22 03:45:41 CST 2023]
------------Combo DEV ATTR--------------
   Devno  WorkMode  DataType   WDRMode         LinkId        PN Swap  SyncMode  DataEndian  SyncCodeEndian
       0      MIPI     RAW10      NONE  2, 1, 3, 0, 4  0, 0, 0, 0, 0       N/A         N/A             N/A
------------MIPI info-------------------
 Devno EccErr CrcErr HdrErr WcErr fifofull   decode
     0      0      0      0     0        0  unknown
  Physical:       D0       D1       D2       D3       D4       D5
                   0        0        0        0        0        0
   Digital:       D0       D1       D2       D3    CK_HS  CK_ULPS  CK_STOP   CK_ERR   Deskew
             hs_idle  hs_idle  hs_idle  hs_idle        0        0        0        0     idle
[VI BE_Dbg_Info]
VIPreBEDoneSts          :0x0            VIPreBEDmaIdleStatus    :0x0
[VI Post_Dbg_Info]
VIIspTopStatus          :0x0
[VI DMA_Dbg_Info]
VIWdma0ErrStatus        :0x0    VIWdma0IdleStatus       :0x0
VIWdma1ErrStatus        :0x0    VIWdma1IdleStatus       :0x0
VIRdmaErrStatus         :0x0    VIRdmaIdleStatus        :0x0
[VI ISP_PIPE_A FE_Dbg_Info]
VIPreFERawDbgSts        :0x0            VIPreFEDbgInfo          :0x0
[VI ISP_PIPE_A]
VIOutImgWidth           :1920
VIOutImgHeight          :1080
VIInImgWidth            :1920
VIInImgHeight           :1080
VIDevFPS                :   0
VIFPS                   :   0
VISofCh0Cnt             :   0
VIPreFECh0Cnt           :   0
VIPreBECh0Cnt           :   0
VIPostCnt               :   0
VIDropCnt               :   0
VIDumpCnt               :   0
[VI ISP_PIPE_A Csi_Dbg_Info]
VICsiIntStatus0         :0x0
VICsiIntStatus1         :0x0
VICsiCh0Dbg             :0x0
VICsiCh1Dbg             :0x0
VICsiOverFlowCnt        :   0
VICsiCh0WidthGTCnt      :   0
VICsiCh0WidthLSCnt      :   0
VICsiCh0HeightGTCnt     :   0
VICsiCh0HeightLSCnt     :   0
It seems the camera not working normaly? as the fps is always 0.
Is there any problem in my program?
I have successfully made the demo work. code updated.
Hi,
Where can I find the CVI MIPI code, i.e. cvi_mipi.h?
Thanks,
Bruce
I found it in the Duo SDK. Was looking in OpenCV.
