milkv-duo environment compilation
基于milkv-duo环境编译
Milk-V Duo是一个基于CV1800B芯片的超紧凑嵌入式开发平台。它可以运行Linux和RTOS,为专业人士、工业ODM厂商、AIoT爱好者、DIY爱好者和创作者提供了一个可靠、低成本和高性能的平台。
安装
虚拟机
VBox + Ubuntu20.04
依赖
sudo apt install pkg-config build-essential ninja-build automake autoconf libtool wget curl git gcc libssl-dev bc slib squashfs-tools android-sdk-libsparse-utils jq python3-distutils scons parallel tree python3-dev python3-pip device-tree-compiler ssh cpio fakeroot libncurses5 flex bison libncurses5-dev genext2fs rsync unzip dosfstools mtools tclsh ssh-client android-sdk-ext4-utils
wget https://github.com/Kitware/CMake/releases/download/v3.26.4/cmake-3.26.4-linux-x86_64.sh
chmod +x cmake-3.26.4-linux-x86_64.sh
sudo sh cmake-3.26.4-linux-x86_64.sh --skip-license --prefix=/usr/local/
添加一些package
source ./build/cvisetup.sh
menuconfig
# 可以添加或者删除一些软件和配置
编译打包
可以查看env.sh源代码
说明每个平台是不一样,希望大家稍微修改哈
#!/bin/bash
MILKV_BOARD_DIR=milkv
MILKV_BOARD_ARRAY=
MILKV_BOARD=
MILKV_BOARD_CONFIG=
current_dir=$PWD;
toolchain_name[0]="riscv64-elf-x86_64"
toolchain_name[1]="riscv64-linux-x86_64"
toolchain_name[2]="riscv64-linux-musl-x86_64"
get_toolchain() {
f1=$(find . -name ${toolchain_name[0]} )
f2=$(find . -name ${toolchain_name[1]} )
f3=$(find . -name ${toolchain_name[2]} )
if [[ $f1 && $f2 && $f3 ]]; then
echo "${toolchain_name[0]} ${toolchain_name[1]} ${toolchain_name[2]} is found."
echo "Toolchain does not exist, download it now..."
toolchain_url="https://sophon-file.sophon.cn/sophon-prod-s3/drive/23/03/07/16/host-tools.tar.gz"
echo "toolchain_url: ${toolchain_url}"
toolchain_file=${toolchain_url##*/}
echo "toolchain_file: ${toolchain_file}"
wget ${toolchain_url} -O ${toolchain_file}
if [ $? -ne 0 ]; then
echo "Failed to download ${toolchain_url} !"
exit 1
fi
if [ ! -f ${toolchain_file} ]; then
echo "${toolchain_file} not found!"
exit 1
fi
echo "Extracting ${toolchain_file}..."
tar -xf ${toolchain_file}
echo "Extract ${toolchain_file} failed!"
exit 1
fi
[ -f ${toolchain_file} ] && rm -rf ${toolchain_file}
IFS='.' read -ra parts <<< "$toolchain_file"
echo "$current_dir/${parts[0]}/gcc/${toolchain_name[0]}/bin" >> env.txt
echo "$current_dir/${parts[0]}/gcc/${toolchain_name[1]}/bin" >> env.txt
echo "$current_dir/${parts[0]}/gcc/${toolchain_name[2]}/bin" >> env.txt
if [ "$(source env.txt)" ]; then
echo "source env.txt";
fi
fi
function get_available_board()
cd ${MILKV_BOARD_DIR} || exit 1
MILKV_BOARD_ARRAY=( $(ls boardconfig*.sh | sort | awk -F"[-.]" -v OFS='-' '{print $2, $3}') )
echo "${MILKV_BOARD_ARRAY[@]}"
if [ ${#MILKV_BOARD_ARRAY[@]} -eq 0 ]; then
echo "No available board config"
exit 1
elif [ ${#MILKV_BOARD_ARRAY[@]} -eq 1 ]; then
# Only one board
echo "Ready to build: ${MILKV_BOARD_ARRAY[0]}"
MILKV_BOARD=${MILKV_BOARD_ARRAY[0]}
echo "other board"
fi
if [ -z "${MILKV_BOARD// }" ]; then
echo "No board specified!"
exit 1
fi
get_toolchain
get_available_board
export MILKV_BOARD="${MILKV_BOARD}"
cd "${current_dir}" || exit 1
MILKV_BOARD_CONFIG=${MILKV_BOARD_DIR}/boardconfig-${MILKV_BOARD}.sh
if [ ! -f ${MILKV_BOARD_CONFIG} ]; then
echo "${MILKV_BOARD_CONFIG} not found!"
exit 1
fi
source ${MILKV_BOARD_CONFIG}
source build/${MV_BUILD_ENV} > /dev/null 2>&1
defconfig ${MV_BOARD_LINK} > /dev/null 2>&1
echo "OUTPUT_DIR: ${OUTPUT_DIR}" # @build/milkvsetup.sh
if [ $# -eq 1 ];then
fi
执行如下命令:
# 第一次编译时候可以用
./env.sh
# 不是第一次编译时候可以用,先清理缓存
# ./env.sh arg1 arg1表示参数1,内容没固定,随便写
./env.sh 1
或者想在镜像添加一些文件,如python,gdb等,需要如下命令:
menuconfig
# 可以选择你喜欢的东西,然后可以运行
上述步骤,正常运行编译打包,导出image镜像,如下:
install/soc_cv1800b_milkv_duo_sd/milkv-duo.img
烧录方式可以是SD卡或者其他工具
判断是否成功
测试ping 192.168.42.1
需要安装依赖驱动哈
建议
- 不要安装在Windows系统下编译
- 即是在Windows用wsl环境下配置,不建议
- 在Linux或者容器或者虚拟机,不要直连Windows下路径,有时候莫名其妙出一些问题
- 搬抄按照步骤去做,发现有一些依赖文件没安装,需要分析一下
