Fedora-RISCV-Builder
Getting Started
Supported Devices
Milk-V Duo
QEMU
Build Manually
- LicheePi 4A
git clone https://github.com/chainsx/fedora-riscv-builder.git && cd fedora-riscv-builder
bash build_lpi4a.sh
- Milk-V Duo
bash build_milkv-duo.sh
- QEMU
bash build_qemu.sh
Download Pre-built Systems
- Username:
root
- Password:
fedora
Instructions
The project requires a file named fedora-38-core-rootfs.tar.gz
to be built using a Fedora 38 host with the RISC-V architecture. The build process is as follows. If you do not wish to build it yourself, you can use the pre-built file provided by the project.
sudo su && cd ~
WORKDIR=$(pwd)
cd $WORKDIR
mkdir rootfs
mkdir -p rootfs/var/lib/rpm
rpm --root $WORKDIR/rootfs/ --initdb
rpm -ivh --nodeps --root $WORKDIR/rootfs/ http://fedora.riscv.rocks/repos-dist/f38/latest/riscv64/Packages/f/fedora-release-38-34.noarch.rpm
mkdir -p $WORKDIR/rootfs/etc/yum.repos.d
cp /etc/yum.repos.d/*repo $WORKDIR/rootfs/etc/yum.repos.d
dnf --installroot=$WORKDIR/rootfs/ install dnf --nogpgcheck -y
cd $WORKDIR/rootfs
tar -zcvf fedora-38-core-rootfs.tar.gz .
This way, you will obtain the fedora-38-core-rootfs.tar.gz
file required for the project script in the /root
directory.
