The source of this requirement comes from the previous post, where we needed to store data for mosquitto message persistence, and the best storage solution is a database. So, let’s proceed with cross-compiling the widely-used SQLite3 for embedded systems.
I. Source Code Acquisition
Official website SQLite Download Page
https://www.sqlite.org/download.html
The current latest version is sqlite-autoconf-3420000.tar.gz (3.00 MiB), and we will download it.
Unpack it on Ubuntu:
tar zxvf sqlite-autoconf-3420000.tar.gz
Navigate to the source code directory:
cd sqlite-autoconf-3420000
II. Cross-Compilation
Create the build directory:
mkdir build
cd build
Enable the riscv cross-compilation environment:
source the cross-compilation toolchain
By typing riscv and pressing TAB, the toolchain name should auto-complete, indicating that the environment is set up.
Generate the build files:
../configure --enable-readline=no --host=riscv64-unknown-linux-musl --prefix=$(pwd)/install_cv1800b
After completion, modify the Makefile in the build directory to add some compilation parameters specific to the chip:
Add C/C++ compilation parameters on lines 255-256:
CFLAGS = -g -O2 -mcpu=c906fdv -march=rv64imafdcv0p7xthead -mcmodel=medany -mabi=lp64d
CPPFLAGS = -mcpu=c906fdv -march=rv64imafdcv0p7xthead -mcmodel=medany -mabi=lp64d
Save and exit.
Then compile and install:
make install
In the build directory, the install_cv1800b directory is generated.
Copy the executable files under bin to /usr/bin on the development board. Also, copy all dynamic libraries (.so files) under lib to /usr/lib on the development board.
Now you can use it on duo, and for application-level development, link to the libraries below and include the referenced header files.
III. Using on duo
You can check the version by running sqlite3 --version.
If you need to perform database operations from the command line, you can run sqlite3 to enter command mode, where you can create a database, add, query, update, and delete data.
For more details, you can enter help to see the usage.
IV. Software Package Acquisition
As usual, for the convenience of those who prefer pre-compiled packages, I provide the install directory and a compressed package for one-click installation on duo.
