First, let’s look at the image:
By replacing the root file system (rootfs), it is possible to run the Arch Linux RISC-V system on milkv-duo.
The following compilation work was done on Ubuntu, and serial connection was made using MobaXterm on Windows.
Step 1: Compilation
Modifying the kernel configuration
First, we need to modify the kernel configuration to add the required features (mainly to meet the dependencies of systemd
Path:
build/boards/cv180x/cv1800b_milkv_duo_sd/linux/cvitek_cv1800b_milkv_duo_sd_defconfig
diff --git a/build/boards/cv180x/cv1800b_milkv_duo_sd/linux/cvitek_cv1800b_milkv_duo_sd_defconfig b/build/boards/cv180x/cv1800b_milkv_duo_sd/linux/cvitek_cv1800b_milkv_duo_sd_defconfig
index 6c05a05df..d214f4fe0 100644
--- a/build/boards/cv180x/cv1800b_milkv_duo_sd/linux/cvitek_cv1800b_milkv_duo_sd_defconfig
+++ b/build/boards/cv180x/cv1800b_milkv_duo_sd/linux/cvitek_cv1800b_milkv_duo_sd_defconfig
@@ -260,3 +260,23 @@ CONFIG_ADVISE_SYSCALLS=n
CONFIG_SIGNALFD=n
CONFIG_TIMERFD=n
CONFIG_EPOLL=n
+# for arch linux
+CONFIG_CGROUPS=y
+CONFIG_CGROUP_FREEZER=y
+CONFIG_CGROUP_PIDS=y
+CONFIG_CGROUP_DEVICE=y
+CONFIG_CPUSETS=y
+CONFIG_PROC_PID_CPUSET=y
+CONFIG_CGROUP_CPUACCT=y
+CONFIG_PAGE_COUNTER=y
+CONFIG_MEMCG=y
+CONFIG_CGROUP_SCHED=y
+CONFIG_NAMESPACES=y
+CONFIG_OVERLAY_FS=y
+CONFIG_AUTOFS4_FS=y
+CONFIG_SIGNALFD=y
+CONFIG_TIMERFD=y
+CONFIG_EPOLL=y
+CONFIG_IPV6=y
+CONFIG_FANOTIFY
Other configuration modifications
Increase the size of memory and the root file system partition (the default size may not be enough for the Arch Linux root file system that we will use later):
diff --git a/build/boards/cv180x/cv1800b_milkv_duo_sd/memmap.py b/build/boards/cv180x/cv1800b_milkv_duo_sd/memmap.py
index 84161267a..99d640134 100644
--- a/build/boards/cv180x/cv1800b_milkv_duo_sd/memmap.py
+++ b/build/boards/cv180x/cv1800b_milkv_duo_sd/memmap.py
@@ -40,7 +40,7 @@ class MemoryMap:
\# Multimedia buffer. Used by u-boot/kernel/FreeRTOS
\- ION_SIZE = 26.80078125 * SIZE_1M
\+ ION_SIZE = 0 * SIZE_1M
H26X_BITSTREAM_SIZE = 0 * SIZE_1M
H26X_ENC_BUFF_SIZE = 0
ISP_MEM_BASE_SIZE = 0 * SIZE_1M
diff --git a/milkv/genimage-milkv-duo.cfg b/milkv/genimage-milkv-duo.cfg
index 40a95c7fb..ef89f3d79 100644
--- a/milkv/genimage-milkv-duo.cfg
+++ b/milkv/genimage-milkv-duo.cfg
@@ -13,7 +13,7 @@ image rootfs.ext4 {
ext4 {
label = "rootfs"
- size = 256M
+ size = 1G
image milkv-duo.img {
Starting compilation
Compile directly using the official command:
cd duo-buildroot-sdk/
./build_milkv.sh
or
Step 2: Modifying the root file system
Importing the Arch Linux root file system
First, download the root file system from the Arch Linux RISC-V project:
cd to/a/location
wget https://archriscv.felixc.at/images/archriscv-2023-07-10.tar.zst
Then mount the img
image that was compiled earlier for modification:
- Find the
loop
device:
sudo losetup -f
In my case, the output is /dev/loop18
, you will need to modify this number according to your actual situation in the future.
2. Binding img
Image with loop
Device:
sudo losetup -P loop18 /path/to/duo-buildroot-sdk/install/soc_cv1800b_milkv_duo_sd/milkv-duo.img
- Mounting the
rootfs
Partition
sudo mkdir /mnt/duo-rootfs
cd /mnt/duo-rootfs
Delete the original content
sudo rm -rf ./*
Unzip the arch linux
root file system here
tar -xvf /path/to/archriscv-2023-07-10.tar.zst -C .
Downloading Required Packages
You can download the required packages from https://mirror.iscas.ac.cn/archriscv/repo
After changing the root file system, the official ko
and sh
scripts may not be available (they can be copied from the previous root file system, but dependencies may be missing and need to be resolved later). It is recommended to install the rz
and sz
commands first to use serial transmission of files.
cd /mnt/duo-rootfs/root
wget https://mirror.iscas.ac.cn/archriscv/repo/extra/lrzsz-0.12.20-8-riscv64.pkg.tar.zst
The folks who have resolved the network issue on the development board can directly use
pacman
to install applications
Flashing the TF Card
After downloading and copying the contents to the microSD card, you can unmount the img
image:
sudo umount /dev/loop18p2
sudo losetup -d /dev/loop18
Then you can burn the img
image into the TF card
3. Power On and Connect
After inserting the battery and powering on the board, connect to the development board through the serial port. If everything goes smoothly, you should see the login screen after about 40 seconds.
Default username: root
Default password: archriscv
After successfully logging in, run ls
to see the previously downloaded lrzsz
package. Install it first:
pacman -U ./lrzsz-0.12.20-8-riscv64.pkg.tar.zst
After installation is successful, you can use the rz
command to transfer files:
- Type
rz
, and the shell will prompt you towaiting to receive
. - In MobaXterm, press
Ctrl
+ right-click and select “Send file using Z-modem”, then select the file you want to upload. I have selected the pre-downloadedneofetch-7.1.0-2-any.pkg.tar.zst
package. - Wait for the transfer to complete.
Note: I encountered a phenomenon where the development board became unresponsive when using the
rz
command to transfer large files. It is recommended to avoid transferring large files as much as possible.
Install neofetch
using pacman
, run it, and you should see the interface at the beginning of the article.
I am limited in skills and welcome any corrections or suggestions for improvement! Let’s work together!
